B
		BriGreentea
Hello, I'm using Adobe Audition Cs6 and doing test runs onto cd. First thing I found out is my recording is in 32 bit and was not able to burn it onto a cd unless it was 24. Maybe someone can explain to me why that is.
Second thing I noticed in the saved settings something called "dithering" which I guess in lam en's terms adds a low level hiss but helps clear some distortion. I saw a page from Adobe showing the differences of Triangular and Gaussian and learned a little about that and tried tests on both of these and each of those have a 'shaped' function which. Then after that I'm lost with the "Noise Shaping" if that should even be selected and the Adaptive mode setting.
Last, I am trying to somewhat master each track this time around on my 2013 demo vs my 2012 demo that pretty much on did everything on the mixdown (Cool Edit Pro at the time) such as a fft filter, compression, eq, hiss reduction then the limter.
I've noticed a huge difference on doing each track with these and when I'm done so I know I did it will color code each track. One other thing I didn't really realize I read about was having the db level not to ever reach past -3. Before it was like...if it isn't in the red then should be fine.
As for the final mixdown I'd like to know what other steps I can do to have the best quality audio. I know about the Mastering function that has a exciter/widener and got a good feel on that. I'm wondering is adding a light amount of even more compression on the mixdown a good idea or not? I know after too much compression then it just sounds squirrly but just wondering. The other things to on the mixdown to use? Hiss reduction and or noise reduction? Fft filter? Lastly, if I have my levels correct from the start and go to the near last step of the hard limiter and I want my cd to sound loud as possible, is limiting to -0.1 preferable with any tweeks to the preset such as boost which is preset to 6 db?
Thanks.
Thanks.
