steffeeH
Did a sideproject recently, and now I thought "Hey why not upload it here and give people the chance to mix it as they like", so here you go!
It's a blend of different styles, but at the core it's kind of Future Garage.
Here's the finished track:
The finished track itself is a little squashed here and there since I was too lazy to actually take the time and get a "good" limiting (since it's just a sideproject). It's also just quickly mixed (meaning it's far from perfect). But you get the concept of the track..
Here are the individual raw tracks, the full raw track, and the finished track:
https://www.dropbox.com/sh/408yhl4lh9j3fnl/AABAbt2WSm01dfoqD6Nrgmvva
A little info:
- The track is at 110 BPM and in the key of E.
- I removed the sidechained compression. But I included the sound that I use as a sidechain triggerer (labeled that among the tracks). It's a short infrasound at a very low level, so pull the threshold all the way down and route the trigger away from the master and you should be set.
- The format is 24-bit 44,1 kHz.
- If you wonder why the volumes are different from the finished track, that's because I messed with them so they're not already done when you import the tracks.
All synths and effects are programmed from scratch.
Looking forward to hear all your ideas!
Good luck!
A little info:
Good luck!
