nessbass
There's a thing I wanted to ask about my mix: Do you, especially if listening on headphones, perceive anything "special" about the panning on the guitars and vocals? It's not moving around or anything, but I used not only differences in volume (like normal panpots do), but a combination of level and runtime differences, like a near-coincident (like ORTF or NOS) micing technique would have provided to achieve the panorama positions.
Edit:
I thought maybe I should illustrate this. So I bounced the first 12 bars of the rhythm and the lead guitars panned left and right using three different settings. In this file, you can first hear the method I used in my mix. Both guitars are attenuated by 6.125dB and delayed by 0.522 milliseconds on one side each. In the second 12 bars, the guitars are panned to each side using the normal panpot such that the volume differences are roughly the same as in the first 12 bars and the stereo meter shows them in the same place as in the first example. The panpots (which go to 64 on both sides) read 18 in this case. In the third run through, I tried to match the stereo positions from example one only using the panpots. Here, they read 50. After that, I pasted example one again for comparison.
In all three settings, I didn't alter the reverb the guitars ran through, the seeming differences in reverb level and EQ are just the different panning methods working.
For best effect, listen on headphones.
What do you think?
Edit:
What do you think?
Really, thanks, I checked out the site and got the plugs. The new mix is huge sounding. The bass gtr is a mile wide. Much respect for your mixing ability.
