nessbass
I'm not the Bear, but I'll take a shot at answering your question...
Listen again to those overhead tracks panned hard left/right. Notice the 'hole' in the middle and how really everything seems to be stereo? This is what you try to avoid. So start panning them inwards and see what happens. At some point the two tracks will gel together and the snare and kick will become more defined, the two tracks will sound as though they belong together more (I don't now how to describe it better). So,
Another word on 'correct stereo image'. Blue Bear already mentioned that the overhead tracks were marked left and right from the drummer's point of view. So another thing to consider is whether you want to mix the whole drumset from the drummer's point of view (like I did, for example), then you have to pan the hihats and the toms accordingly (hats left, toms slightly left and slightly more right), or from the audience's point of view like Blue Bear did (hats on the right, toms right to left). This is a very important thing to consider, and it almost doesn't matter to do it either way, it's more of a philosophy thing.
Oh, and gentlemen, keep on sucking, it feels sooo good.
Originally posted by Chibi Nappa
just wondering what you listen for when panning the overheads to make a correct sterio image.
yes, this is basically it.Do you just twiddle to pan knobs until you hear the individual drums/cymbals coming from well-defined locations?
Basically, you have to watch out for that 'hole' in the middle. When there's nothing coming from in between your speakers, it's too much. But instead of using a spaced pair technique, like fenix did here, you can use the xy-technique, which helps to achieve a more precise image of the drumset while minimizing phase issues.What do you check when placing overheads in the first place to avoid this?
Frankly, those were hurting my ears. His interperatation of the bass in general, and particularly the interaction between the bass guitar and kick were, again, refreshing (I like it better the more I listen to it), but not every guy's cup of tea.
