BroKen_H
Re-member
Okay. Got the Vox AC15. Got the Les Paul. I'm getting some KILLER tones out of the pair (and with the other guitars in the stable). Overcame the new buzzes and rattles that came with a louder amplifier.
But when I point the 57 at the speaker (at any angle, distance and position) it sounds like I've left the high pass on. I could get the sounds that were coming out of my Cube to sound pretty much like they came out of the amp, but just switching the amp out has given me this new problem. Best sound on the Cube was straight on about 1/2"-1" left of the cap. In the Vox, I can't see the speaker, but I'm pretty sure it's in the middle where the cloth is not backed by solid wood. I've tried 1/2 inch increments all along the vertical center. Should I be aiming higher or lower with this louder amp? Should I pull the mike back from the grill? Should I be doing more than about 10 degrees axis? I've experimented and everything I've tried sounds mediocre to awful.
Any help or article links or whatever would be greatly appreciated. In the mean while, I just keep experimenting (and yes, I understand that's important, but I'm a bit lost and confused, thank you very much).
