R
rush1974
hi guys . . just wondering what is the max length you can have your midi cables at . I have to run the cable from 1 room to the other and the length i need is about 40 to 50 ft . can midi cables be that long . i know i can by a cupling and connect them but don't want to have any joinings .
also, instead of using an adaptor and joining 2 20ft cables , i was thinking of making my own 50ft cable using the network data cable and putting connectors at both the ends . can you use network cables using only 5 wires from there with connectors at the end instead of the actual midi able .
will that work .
thanks
will that work .
thanks
