B
buck78
After doing some reading on MS Stereo recording, I did some thinking (that can be dangerous).
I will be recording my father-in-law's bluegrass band in the near future. They are a four piece band (banjo, 2 guitars, bass). I am using a Boss BR-532 recorder which only allows 2-Track recording.
My inital concerns for recording were/are banjo and bass bleed. The bass can be fixed by over-dubbing that part after the fact. My fix for the banjo was/is to record that part on a separate track. To reduce the bleed into the other mic I figued (no pun) to set it to the figure 8 pattern (B3). By placing a make shift gobo between the mics and lining up the banjo in the figure 8 dead spot I should be able to reduce the bleed enough.
So both my guitarists are singing and playing into their respective sides of the figure 8 mic. Here's my question (finally!). If I re-record this track, while flipping the phase, will I be able to "separate" them into two tracks? I plan on doing this by running the signal from the recorder through my pre-amp (DMP-3) and flipping the phase reversal button.
If this doesn't work, I still feel that I will have a good recording. If it does work, I'll have a good recording and an even better mix. See, if I had a 16-track monster that could record 8 tracks at a time I would never learn this stuff.
Thanks for reading. Any input is welcome.
Buck
Buck
