aaronmcoleman
The truth is out there!
I was just playing around with some micing methods for acoustic guitar and wanted some help with Mid/Side decoding.
I used an NTK for the mid, and a FatHead for the side. The NTK was aimed directly at the 12th fret, and the FatHead was aimed at 90 degrees.
In Reaper I copied the FatHead and panned one hard right and one hard left and inverted the phase on the right. With the NTK muted, and both Left and Right faders set to 0 the volume was even on the right and left sides. As I brought the NTK up, the volume on the phase inverted side got way higher. I know this has something to do with the phase cancellation.
Basically in decoding the mid side, I had to lower the phase inverted side a lot (a whole lot, like 10db) to get both left and right at the same volume. I think it sounds good, but is this the way M/S recording works?
