dgatwood
is out. Leave a message.
and i find that there is no practical difference btween cheap stands and expensive stands. like someone said regardless of stand quality, if the boom is all the way out its going to fall. save yourself some cash and stick with the "cheaper" stands and add some weight to the opposite of the boom.
I disagree. I've used cheap, lightweight boom stands and many of them at full extension won't even hold an SDC without the boom and/or upright sagging/flexing even if you take care of the tipping problem by positioning it over a leg. They also have poor clutch designs that last four or five years before the rubber parts wear out and the boom won't stay at any angle no matter what you do. There's a huge difference between the $20 stands and the $40 stands if you're dealing with booms.
And the really heavy duty ones are tough as tanks. My biggest stand has teeth on the boom clutch so it cannot drop. When putting a mic twenty feet in the air, you really need that level of robustness. Unfortunately, that's the sort of thing you can't tell from a simple photo and a description from a website. It pays to go see these things in stores if you can.
This photo demonstrates the difference between lightweight mic stands and somewhat heavier mic stands:
Notice two things:
1. The cheap mic stand is curved from the weight of an Oktava MK-012 and tends to sag on its own.
2. The Tama mic stand is holding two cymbals and a 10" rack tom. The cymbal gets regular use.
