A
Adrian Lopez
I've recently purchased an MXL 990 condenser microphone along with a Behringer UB1002 mixer so I can record my violin playing onto my computer. When I received the package from Musician's Friend I noticed the shipping box had been exposed to water (it was wet and had developed a tear along the length of one of its top edges). The boxes inside were mostly okay, although perhaps a little humid in small areas. Having never used such equipment, I have no way to judge whether it's working properly.
With a level of 0 on the "mic in" and "main mix" faders, I find that I have to raise the gain on my UB1002 to around 50dB to get the signal level indicator to peak at 0 when playing my violin from a couple of feet apart (which is closer than I'd like). Should the microphone really require that much gain? The MXL 990 has a sensitivity of 15mV/Pa, and according to Harvey Gerst's post on microphone sensitivity a sensitivity rating of 10mV/Pa would require 40dB gain while a sensitivity of 20mV/Pa would require 34dB gain. It seems that I shouldn't have to set the gain to 50dB in order to obtain a reasonable recording level.
I am concerned that either the microphone or the mixer may be malfunctioning because of the damage to the shipping carton, but I can't be sure whether that is the case (the equipment itself didn't get wet, as far as I could tell). If the equipment is not malfunctioning it would seem the microphone isn't very good for use in distant miking applications. I've seen how orchestras suspend pencil mics from the ceiling, and I don't think the MXL 990 could function at such a distance (from ground-level, of course).
This brings me to the matter of microphone sensitivity and its relationship to recording distance. I've been considering an MXL 603s as an alternative to the MXL 990, but I noticed its sensitivity is 15mV/Pa, just like the MXL 990. I am concerned that if I purchase this microphone I'll experience similar problems with gain and distance.
Is it possible for two microphones with identical sensitivity ratings to behave differently in terms of possible recording distances? Would the MXL 603s be more appropriate for distant miking than the MXL 990?
Aside from my awful playing I don't really like the sound of the MXL 990 on my violin and some people recommend the MXL 603s for such an application. If I'm going to spend $280 dollars on a stereo pair, however, I'd like to know whether it's able to perform at reasonable gain levels in distant miking applications.
I would appreciate any input on how to judge whether my equipment is working properly and whether the MXL 603s is better for distant miking than the MXL 990.
