Microphone advice
  • Thread starter Thread starter dja360
D
dja360
Hi there,
I'm a newbie to home recording and have recently purchased some equipment to record spoken word (in particular podcasts). I'm using a Zoom H4n to record on but I'm wondering if I've got the right mics.
I was sold two se3 condenser microphones (end of line so going cheap) but I'm not sure if they are the best thing to use. You can view the product here
I've used the mics in a few indoor locations (which are mostly quiet) and while the se3's record a nice clean sound of the speaker they are also unbelievably sensitive to any noise around them. I can hear doors closing in rooms next to me, footsteps above as well as any ambient noise in the room. They even picked up a police siren wailing outside.
When I record, the mics are always on a table in front of the speaker, about 12" from the mouth, and placed on stands with shock mounts.
Should I have a different type of mic or is there something I can do with the mics I have. Most locations I record in are offices so I'm expecting some noise but these things are hyper-sensitive.
Any help greatly appreciated.
Dan
I have the same problem with all my condencers... I don't think there is anything you can do about it aside from sound proofing the areas your recording in. I am sure some of the more expensive mic's have better noise rejection but I don't think you can eliminate the problem entirely.
What I do to eliminate back ground noises or breathing sounds (often called debreathing) I analyze the signal I recorded in sonar 8.5 and use vvocal to reduce the volume level between phrases to 0.. during the phrases the vocals are so loud I cannot hear any of the background noise anyway.
You could use dynamic mics which seem to have better ambient noise rejection, especially hypercardioid or supercardioid pattern.
Here's one on sale:
http://pro-audio.musiciansfriend.com/product/Electro-Voice-PL24-Dynamic-Vocal-Microphone?sku=482560
You could mic closer to the people speaking and turn down the gain.
You could buy or build some sort of blocking panel to put behind the mic.
https://homerecording.com/bbs/showthread.php?t=302646
https://homerecording.com/bbs/showthread.php?t=278653
http://accessories.musiciansfriend.com/product/sE-Electronics-SERF-Reflexion-Filter-3.5?sku=270353
