J
joswil44
I generally have been doing ok recording heavily distorted guitars, but recently I had the second occurance of recording guitars where I believe too close of mic placement and amp volume combination have created a hint of fuzzyness that I cant seem to get rid of without re-tracking.
I think part of the problem stems from Recording all the drum tracks for many hours with headphones on.
By the time I am tracking guitars my ears have probably fatigued a bit and I didnt catch that fuzzy sound when I was searching for good mic placement.
The rough mix was pretty decent but by the time I got to mastering I really couldnt avoid bringing out the ambient fuzzy noise from the guitar tracks.
As far as micing goes, I generall use a 2 different guitar cabs, 2 different guitar heads, and 2 different mics.
For this session I used a Marshall TSL100 I believe, and my own Peavey Triple XXX head. We played through a Mesa 4x12 Cab Vintage 30 Cab and Marshall 1960A 4x12 Cab.
I used a Beta 57 on the Mesa Cab and an Audix I5 on the Marshall Cab.
Mic Placement was basically within 1-2 inches from the grill cloth around the outside edge of the cone slightly angled in toward the center of the cone.
I felt as the the sound was fine at the time but am wondering if I should have backed away from the speaker a bit more.
I am curious what range of distance people are using when micing?
And do you back up a bit on fairly loud volumes?
I guess I was affraid of making the guitar sound a little distant.
If you track at 3 or 4 inches away will it turn out alright with some compression or something later on?
Anyone else have any safety guidelines for circumstances like this so you dont have to go back and redo what you couldnt necessarily hear the first time?
) until you get a sound you really like. I like to do the same with an LDC 3-5' away from the amp, pointing at one of the speakers.
