Well, assuming you are still looking for a "clean" preamp, some of the other obvious and more popular choices would be Millennia, Hardy, Grace, DAV and perhaps Speck. If you want a bit more "color", the choices expand considerably.
I don't think I want the sound to be too antiseptic, but I'm not looking to make my guitars sounds like kazoos either. But the information I've gotten on this board has been incredible helpful.
BIG BIG THANKS TO EVERYONE!!!
I think I've narrowed it down a bit. Of course, as soon as you think you've got it down to just a few, a new one pops up and charms you, doesn't it?
So here's my short list:
John Hardy M2 with the 20 ohm option rather than the 20db pad
A-Designs MP-2A (which might be the ugliest piece of gear I've ever seen)
Demeter VTMP-2C
and a late entry to the race is the Wunder
PAFOUR
I still have some questions though...
My TwinTrak allows me to vary the input inpedance and I've found that it makes a big difference in the sound I get. With the exception of the Hardy which gives me two choices, none of the other pres allows any adjustment. Is this just less of an issue on higher end gear for some reason?
My Liquid Channel doesn't give me any options either, so maybe that's it. Maybe on the higher end gear it just doesn't matter that much, but I'd love to know why.
The next thing I'm struggling with is tube or no tube. I'm just not sure how warm I need the guitar to be in the mix. I'll more than likely be recording my vocals with an AKG Solidtube into the Liquid Channel (the Solidtube really works well for my voice), so I get some nice warmth there. I don't think I'll be recording the guitar tracks with tube mics.
The Blue Woodpecker, a ribbon, will be in the mix, but there won't be a tube mic in front of the guitar anytime soon. My main guitar mics are the Woodpecker, C414B-XL II, C451B, and an Earthworks SR30. If the vocals are warm, should the guitar stay towards the warm side or should the guitar give some contrast?
I know the standard response is "go with which pre sounds best" but the one that sounds best by itself may not be the one that sounds best with my voice in the mix.
My gut tells me to go with the tubes because it's probably easier to eq some of that away rather than try to add it later. Am I wrong on that?
