You didn't mention your monitoring situation, so I'd wonder if that's where you need to upgrade, and I'd upgrade the interface/pre situation as long as you've got >500 monitors...
As for what interface/pre that's a complicated situation. Do you want an all in one pre and interface? A seperate interface with a seperate pre? How many channels? Do you want it to be very customizable or simply straightforward?
If I had 600 to get a pre and interface, I'd look at getting a Delta 1010 and a pair of M-Audio DMP3's. Used if you can find them...the 1010 you can get used for 300ish and a DMP3 can be found for 120ish each. Next I'd also get some custom cabling done, some quad-star mic cables and TRS Cables. If you're smart, you can make them yourself or get someone like me to make em for you. 300 plus 120x2 plus 60 worth of cables totals 600...Then when you get some more cash start to add mics to your collection...try not to get rid of what you have, it's a relatively good mic and it will only benefit you to hang on to it!
Keep in mind that this is only my humble opion based on what I would do with what you've got to work with in equipment and budget.
Jacob
