L
LeoZ
Hey my problems are:
1)Really low mic recording output even though preamp gain/output is set to full. I have to EQ the output to even hear it.
2)The output has a really high noise level, almost louder than the vocals.
I'm using a SEx1 Condenser mic (with phantom power) -->Lexicon Alpha Preamp (monitor mix halfway, output set to full, XLR intput) --> Macbook running Logic Pro (record enable).
Is it normal for low outputs that require channel EQ-ing to even be heard?
Any advice for sources of this background noise and how to eliminate it? Could it be some form of interference, alternatively I split coffee a couple of weeks ago. I completely dried my computer and the USB ports work fine, but could this cause some sort of problem with the preamp input?
Any advice/help would be really appreciated- thanks!!
