Z
zbyrne
Hey guys! First post.
Brand new to pod-casting, invested in some equipment and I'm giving it a shot! Tried doing a couple recordings the other night, but could not get my second mic to record well. Heard both of us fine through the headphone monitoring system - but my co-host was only getting picked up through my mic on the recording.
So this is my setup:
Mackie 1202VLZ4 Mixer
Zoom H6 Recorder
Behringer 4-Channel Headphone Amp
ATR 2100 USB Microphone's
I have my H6 connected to my mixer using a R/W TRS Main Out to a single TRS going straight into Line 1 of the recorder. I have my headphone system connected similarly to the Behringer splitter (the R/W connectors being plugged into the splitter). Everything sounds fine through our headphones when recording into the Zoom, but when I remove the SD card to play it back into my computer it's as if my co-hosts mic is off, or at least, recording very faintly. When I look at the level readings on the Zoom, speaking into my mic makes the readings rise to proper level, but when he speaks into his it barely gets a blip. I have our 2 mics plugged into the mixer's Line 1 and Line 2 respectively with XLR cables and settings identical on each. Any thoughts to shed on this? I can post pictures if needed.
Additionally, there is some static (which I could probably eliminate by playing with the different volume controls) but I figure deal with one issue at a time although any advice on how to reduce that, or what's causing it, would also be appreciated. Thanks a lot in advance guys! I know a lot goes into learning this stuff and I appreciate your time.
Zoom H6 Recorder
