rayc
retroreprobate
I finally got around to doing a mic comparison.
There are 7 mics in the run.
For the sake of consistency I ran them all through a Beringher MIC 100 preamp with the output all the way up & adjusted the input so that all mics registered approx the same level on a percussive sound. The pre does add noise.
ALL mics were set on the same goose neck and aimed just below the soundhole of a no name acoustic and all at approx 12 cm distance.
Against my personal preference I used a little, soft, flexible acoustic pick (I like a medium to heavy bass pick with fangs usually) as I figured it was more in keeping with the equipment others use.
I tried to play at an even level & speed - same chord sequence all through so I'm sorry if it bores you.
Each mic is announced on the file (funnily enough the tiny little PC mic - non usb - did a VERY good job of this considering I did the announcing later through a sound blaster mic in on my upstairs comp.)
There's a bit of computer noise & the wife started using the clothes drier in the laundry a hall away part way through but it shouldn't have much impact.
I'd be interested to know what stands up best. I haven't decided. I'll need time & distance before I can listen & compare for my own use.
The streaming link is below but if you want a better qaulity listen you'd be best to use the link in my signature & download the MP3.
http://www.soundclick.com/util/getplayer.m3u?id=4278268&q=hi
The mics - not in order (remember they are announced) are aSony ECM 19B electret condensor, a Shure 57, a Primo DM-260 mini dynamic, a Le Grange DM 110(switched to lo then hi impedence), a Behringer XM8500 Dynamic & a tiny lipstick sized high impedeance dynamic no name.
I couldn't get enough signal from my crystal Hi-Mike DM201 to record and I couldn't find an adaptor for the Realistic Dual Pattern 33-919A Stereo mic.
even pros get board
