Doug H
I'll be there
"How do you do a digital volume adjustment on a file without math?"
This is the beauty of floating point math. In the 32 bits ~25 of them are dedicated to precision, the rest quantify magnitude. Since 24 bit audio only has 24 bits of precision, in theory a 32 bit float should preserve the wave form at any volume.
Since sound cards don't accept 32 bit float streams (do they?), the wave is dithered on output. If you drop al your track faders ndb and boost the master bus by the same amount you shouldn't lose any detail. I beleive a bunch of people did a loopback test a few months ago using different software packages to see which used float internally, most did.
