7string
I use Guitar Tracks Pro 3 and today I was doing some mixing and accidentally RIGHT clicked on one of the track meters. Wow... something new! The first thing that popped up was a box with Current Meter -> and All Meters ->. So I clicked on Current Meter and another box popped up. This one had a whole bunch of choices. 12, 24, 42, 60, 78 and 90 db range. What the hell does that mean? Right now it is set to 42. Is that right?
So I clicked on All Meters and again a whole bunch of options came up. The only one's I was interested in was the Playback Meters and Record Meters. First there is Peak, RMS and Peak + RMS. Then under THAT there is the same options as above, 12, 24, 42, 60, 78 and 90 db range BECEPT! They're all after a "-" negative sign. THAT is set to -42 db range. Is that where it's supposed to be?
How should I set these up and WHAT determines HOW these are set? Would these settings have anything to do with WHY my mixes are so damned low in volume? I can put a regular CD in and can NOT stay in the same room because the volume is so high. I know that these are fully mastered and professionally recorded, etc. But when I go to mix my own recorded tracks the volume is so low it's EXTREMELY hard to hear. So I was wondering if one might have to do with another?
