RandyRhoads1981
Hey there,
I finally got my Multi-Meter working and now
I am going into my Tape Machine to try and
find the culprit of why it isn't working
in Sync Mode and why the Channel 6 Card
is barely responding to any signal.
So... I have some questions:
1)How do I measure the Output of my MS-16 from the XLR connectors?
2)Do I place the Leads on the Hot and Cold pins?
3)Which Lead goes on which pin?
4)Do I need Alligator clampers?
I also want to check some of the components
on the Rec/Play cards.
Specifically the Opamps/IC's.
5)Are there certain pins I need to measure
on the IC's or can I use any?
6)Can they be measured from the top, or
does it have to be from the solder points?
I ask because I don't have an extender card
and the bottom is a very tight spot.
Any advice/input would be very appreciated.
Thanks,
-Thomas
Thanks,
-Thomas
for wacking out such perfectly good machines.
