Okay, continuing on.
After I got the machine running, I knew there were a few things that would have to be done. There are 17 capacitors in the power supply, 15 of which are electrolytic, 4 of which are tantalum. I replaced all 50uf caps with new 47uf caps. Six of those were aluminium electrolytics that looked rather crusty and the other was a tantalum that I thought I'd just replace for the hell of it.
I also replaced the two caps that were not electrolytics with safety caps, again, just because I can. That leaves the five 8700uf main filter caps and three small tantalums on the motor driver board. Two .47uf and one .68uf.
I ordered this nifty little ESR meter kit from Altronics:
K2574 - Silicon Chip Magazine ESR Meter Kit - Altronics Why a kit? Well it is cheaper than one that's already built. This one also seems to be bulkier and better quality than a lot of other ones. And I love soldering, so why not?! Kits are fun!
Anyway, once I have built the kit, I will use it to test mostly tantalum caps throughout the deck. I'm going to assume that most if not all aluminium electrolytics are bad and replace them. Although the 8700uf filter caps in the power supply seem to be doing fine. I checked the supply ripple of the 24 volt supply yesterday and it looked pretty good. I'll check the rest eventually and I may just replace them anyway...
This is embarrassing... Um, I didn't have any...any tape...
Like none! None at all, I had not a single reel of tape. Not even a puny 3" reel... You see, I once sort of gave up on magnetic tape. I just had so many hobbies and tried so many different things looking for fulfillment. One day I just decided I had too much stuff and everything tape related was parted out to people I knew who were interested in such things. I hadn't done anything tape related in about two years, then I got the B67 from my uncle and that interest was sparked up again. Hopefully I'll get more out of it this time.
I have moved since then. I now have much more space to work and to store stuff. I think things will go well!
Anyway, I digress. I bought a reel of tape online. I wasn't worried about whether or not it was good tape. I just needed something to test the transport. This machine uses dynamic braking. "
is that?! " I thought. I had heard the term before and I knew what it meant, but I didn't even know that there were recorders that used that! All the other recorders I ever had used AC motors. Now I have this beast that uses DC motors with tachometers! This machine is probably smarter than I am!
Without tape, I wasn't sure that the machine was working correctly. In fact, I guess I'm still not sure. Without tape, in the fast wind modes, whatever reel is the take up reel at that moment seems to have little if any braking behind it. It seems to me that the inertia is being put through the tape to the supply reel. The supply reel seems to be doing all the braking. I was worried and I still am worried that the tape has too much tension on it when braking from the fast wind modes. I have never worked with dynamic braking in a tape machine. I'm really clueless.
Her's a pic of the machine with tape on it:
I had to give all the guides, heads, rollers, etc. a good cleaning before running tape through it. A lot of bad tape was put through this machine at some point. It took ten minutes to clean each head and the erase head still doesn't look clean. Even some of the guides had to be scrapped to get all the crud off! But it sure is shiny now!
The heads are glass heads? There's a technician's notes in the manual describing slightly pitted glass heads. These ones look like glass and they are slightly pitted. Here's a pic of the heads:
I forgot to clean them before taking the pic... And here's a close up of the playback head:
I really like the look of these heads! They're stylish!
The JH-110A can be up to four tracks. This one is set up for two, but the PCB connector that the head block plugs into still had the four sets of cables. One for each potential track. That was good since I noticed some damage to one of the cables that was used and replaced it with one of the spares. I removed the other spare just to keep things neat. I only need two channels anyway.
Here's what the transport looks like right now with the dress panel back in place:
I am missing one screw for that panel. The yellow light at the far left is an addition that someone made. It comes on when the reference for the capstan speed is in any position other than fixed. Not a bad idea when making a recording I suppose.
The shield for the playback head is manually controlled by the leaver in front of it next to the fast rewind button. The other lever up and to the left of that is a manual control that moves the lifters to pull the tape away from the heads at any moment. It does not work in reverse though.
Well that's my 10,000 words for today! I hope someone enjoys that!
