T
tokyofan
I know there was an earlier thread to this but wanted some further clarification.
I want to connect a Grace Design 101 to my Mbox 1 (XLR/TRS). I've read that if I go through 'line in' it'll still be engaging the mBox's pre. But if I go through the 'inserts' it will BYPASS the pre (but will be unbalanced). If I do that do I need to modify the cable? It's not very long (1 ft).
The Grace's manual says that "if either of the outputs are to be used unbalanced, a modified cable is required and pin 3 (or the Ring) should be left open." Can anyone elaborate on this? And can I modify the cable myself?
