gobblefisher
I'm just curious to hear your suggestions for low noise matched pair omni's under $1000. They'll be used to record chamber music in rooms with good acoustics. Thanks!
gobblefisher said:I'm just curious to hear your suggestions for low noise matched pair omni's under $1000. They'll be used to record chamber music in rooms with good acoustics. Thanks!
gobblefisher said:I use a Mackie Onyx 400F that then goes into both a Fostex D-5 DAT recorder and a Tascam DV-RA1000.
Juggernaut said:Oh yeah, I forgot about the pelusos. They are about 700 per pair and 100 per extra capsul. Omni, Cardinoid, Wide-Cardinoid, and Hyper-Cardinoid are available.
http://www.atlasproaudio.com/peluso.html
Check 'em out at the bottom of the page.
Now tht's funy.Juggernaut said:Well, I mis-typed, and so did you.
I typed Cardinoid.
You typed CARDIOD...
Timothy Lawler said:Now tht's funy.![]()
Juging from how we al type it's amazig that any of us get ANYTHIG recoded accuratly.
Tim
What about lower self noise test/measurement mics like the Audix TR-40 and the THE Audio KP-6M? Does anybody have any experience with those?BigRay said:Location Chamber and Orchestral Music is my full time recording gig, and I have tried all of the big omnis and some of the smaller ones..I suggest grabbing a pair of AT4050s. A pair will be about 800 USD from ebay..The DPA 4060/4061 and 4090 and 4091(and the earthworks) are , IMHO, unuseable due to the self noise. It is immediately obvious to even the most untrained ear. No, they arent sold as matched pairs either because the tolerance standards are supposed to be very strict....now the high end DPA omnis are great ,but the 4060/4061 and 4090/4091 arent very good. (same with earthworks)
The 4050s are flat, very low noise, and are built like tanks. They are also multiple pattern mics, so you could have the opportunity to use blumlein or M/S..(Blumlein is superior to any stereo technique, given that all else is equal, imho)
I would also suggest the ADK SL Series Microphones.They sound PHENOMENAL, price aside.. A pair of those would also be about 800. You could get the SLs and the MSH1s for well under budget.
I also second the jecklin disc. It gives fantastic seperation and imaging, equal to that of a spaced omni pair with none of the unwanted side affects(hole in the middle, uncontrolled LF)..You should not use a omni with an enhanced low end, as due to the nature of the Jecklin/OSS technique, there is a very pronounced roll off of HF , and with "warm" mics , the result will be mud..
Cardiods and omnis both should be in your kit, as well as a low noise, high gain preamp. (transparent is up to you, but low noise and high gain are undebateable)
What are you using, preamp-wise?
gobblefisher said:What about lower self noise test/measurement mics like the Audix TR-40 and the THE Audio KP-6M? Does anybody have any experience with those?
I typed Cardinoid.
You typed CARDIOD.
It is Cardioid.
