5
5150 Musician
Anyone use Sonar 3 for mastering tracks? If so.. if all you're doing is mastering and not recording, is it neccesary to have a really good soundcard?
I do Pseudo-DIY-Low Budget Assembly and Mastering (note that carefully worded walking on eggs technical terms) on Sonar sometimes.5150 Musician said:Anyone use Sonar 3 for mastering tracks?
Good question. At the very minimum, your D/A converter quality (assuming that's in the SC) will be in the monitor chain, for good or bad.If so.. if all you're doing is mastering and not recording, is it necessary to have a really good soundcard?
laptoppop said:and no -- the converters on your sound card are nowhere near what would be used by a solid professional.
pronoise said:Mastering at pro level is a very sophisticated task. And it is almost impossible to do in a homestudio. If you mean dithering down your work and just balance the loudness etc.., you can do it with Tracks, soundforge or Wavelab appz. Sonar 4 will feature pow-r which is one of the best algorithms in dithering, so Sonar will be a player in that field as well.
5150 Musician said:Is processing each track into advanced compression, effects, equalization, acoustic dynamics, as well as any form of stereo imaging and surround enhancement and then begin processing them down to fewer tracks to make fine adjustments for the final mix down while becoming emotionally and physically dismemberd from all the stress considered sophisticated? Or is that just a crap shoot?
rjt said:I would consider that mixing and not mastering, and it may or may not be sophisticated.... kinda depends on how well it is done. (I gather, by track, you mean individual instrument tracks within the context of a song as you talked about making them into fewer tracks and preping for final mixdown.)
Take Care
