McMajik
Is this why there are so fewer threads on the mastering subforum than on the rest of the board?
I know this is funny and all, but let's be fair for second. Or at least indulge me for a second. This little article is talking about "mastering" one track. A single. That's what I noticed anyway. Is that correct? I know that's not technically "mastering", but in a sense it is because you're getting it finished and polished up for final consumption. Now I'm no pro mastering engineer and don't pretend to be one. And maybe 15 minutes really is a laughable amount of time for one track, but how long would it really take a pro M.E. to "master" one track? Let's assume the mix is very well done and everything is tracked properly. Would it take considerably longer than 15 minutes for a pro with pro gear and monitoring to do one 3 minute pop or rock song?
The "rough" settings are done -- well, as long as it takes to make them. 30 seconds to one minute. Dialing things in takes a pass or two.
Assuming there isn't anything "wrong" with it, 15 minutes is a pretty good estimate for working / processing one mix.
Assuming there's more than one, rendering, spacing, QC'ing, authoring, QC'ing that, etc., etc. ups the average quite a bit. But the actual amount of time taken on a single track is probably pretty close.
Keeping in mind that takes a few things into consideration --Ok thanks for that.
We are doing it all wrong.
To heck with our ears, Just slap a multi-band compressor, more compression, cut everything under 30 hz, etc, and voila! A quick "mastered" track!
Absolutely brilliant. I'll never spend a single dime on a trained professional again.![]()
Heck, I just use a limiter and call it "done"!
That's what most of us hacks do. But that's not mastering.
Hello Chaps,how long would it really take a pro M.E. to "master" one track? Let's assume the mix is very well done and everything is tracked properly. Would it take considerably longer than 15 minutes for a pro with pro gear and monitoring to do one 3 minute pop or rock song?
Hello Chaps,
First post here ! Greg, to answer your question, I always allow at least an hour to master a single song. It takes me that long to figure out how it should sound, and what the best way to process it is. After that, subsequent tracks can be quicker and easier, because it's more a question of balancing everything, the overall decision about the sound has been made.
If everything sounds great, it's usually possible to master a ten-track album in 4 hours or so, ie. an average of 25 minutes per song. So in my opinion, 15 minutes is too quick !
Having said that, if it's your own material and you know in advance pretty much what you're going for, maybe it's possible to do it a little faster, as other here have said.
Cheers,
Ian
