Elmo89m
A friend of mine purchased a marshall jcm900 recently. He required a fottswitchable cleanto distortion option and because the jcm only has one channel he uses his metal zone for distortion. This appalled me because i thought the reason for buying a marshall was for its distortion. He explained to me that it really was the marshalls distortion because the sound of the metal zone went the through the marshalls tubes and was being shaped by them. Is this true? Also i played around with the marshall trying to get distortion out of it and there is none. I heard from someone who worked on a silverchair album that on a marshall all setting turned to ten gave really heavy distortion so i did this and it just sounded like crackly boom crap. I tried everything i could think of but could not get an amazing marshall wall of sound type distortion out of it. I couldn't even get distortion as strong as my crappy crate gt-65..why? what do you all do with your marshall's? Thanks al ot
...If you put the gain on 10 and the master volume on or approaching 10 and it doesn't have any gain or any balls it is screwed up. When I've used that amp for high gain stuff I definitely turned it all the way up if that helps any. And at that the amp should ROAR with distortion. BTW - I have also had a JCM800 and the 900 had more gain.
