making mini songs to practice mixinng (metal)
  • Thread starter Thread starter Mr. Cachi
So I've only got small speakers here at work, so I can't give you much technical advice... but I can say that if you want better drums sound... you should turn down your guitars a bit... I guess it's obvious you're a guitar player... which is why the guitars are so loud in the mix... but you need to step away from that point of view if you want a more balanced mix. ;) So yeah, my small advice would be to turn down the guitars a bit as they over power the drums especially towards the end when the solo parts are blazing full speed ahead.
The drums do get slightly buried towards the end but it's not too bad. You might be able to carve some 180ish Hz out of the guitars to make room for the snare. You could also try parallel compression on the drum bus. Fine balancing act between loud enough and too loud
The drums do get a wee bit drowned out behind guitars but they've got good energy and you've done a good job based on that small section.
Mark
