Pin#2 is hot, Pin#1 is ground, Pin#3 is low. It says which pin is which in really small letters on the XLR connector. If you have 2 wire shielded cable, unravel the shield, twist it up. Thats your ground pin#1 white will be hot( if you like) and black will be low.
Hope this helps.
