Product Description
MAudio Firewire 410 Mobile Recording Interface
FireWire 410 is a FireWire-compatible audio/MIDI interface that has it all—power, flexibility, compact size and low price. Its 4-in/10-out configuration with preamps is perfect for personal recording, routing discrete outputs to a mixer, or directly driving a surround sound system. The on-board ASIO 2-compliant mixer and software control panel provide total routing flexibility—including monitoring with external effects. You also get ultra-low latency software monitoring and zero latency hardware direct monitoring—and two headphone outs with independent level controls let you collaborate with a partner anywhere, anytime. FireWire 410 can even be completely bus-powered for total mobile operation*.
Features
2 x8 24-bit analog I/O
192kHz output (output 1 and 2 only; 96kHz on others); 96kHz input
digital I/O w/ S/PDIF, AC3 and DTS (coax and optical)
1 x 1 MIDI I/O
powered via DC supply or FireWire bus*
dual mic/instruments preamps w/ gain control (66dB available gain) and phantom power
2 headphone outs w/ individual level controls
low-latency software monitoring; zero-latency direct hardware monitoring
analog outs can directly drive up to 7.1 surround
software-assigned level controller for tactile control of all input and output levels
2 convenient high-speed FireWire ports
* requires 6-pin FireWire port
Includes Maximum Audio Tools containing a great collection of software so you can make music immediately.
