macmoondoggie
Mr songwriter said:I had a look at the 1010LT's, but they cost about £160, and according to the spec, the built in mic preamps only work with dynamic mics and don't have phantom power (I'm planning to get a condenser) and in any case I'm about to buy a DMP3, so the preamps are neither here nor there, nor do I need that many in's. Also, as I said earlier, the manual for the DMP3 says that the balanced outputs run quieter and hotter than the unbalanced ones, so surely that's quite a big plus, not to mention the supposedly better dynamic range. I've also had a look at the 192's manual and there is also an option in the control panel for choosing the monitor mixer's source when using S/PDIF that isn't present in the 2496's control panel.
The balanced Mic inputs on the 1010LT can be switched to Balanced line in.
