B
Big Kenny
Chessrock roasting on an open fire (sung to the tune of the Christmas Song)
In His Name
Big Kenny
In His Name
Big Kenny
Nitronium Blood said:You have to realise that Chessrock is one of the most respected gurus on this board. Listen to his advice.
Big Kenny said:Chessrock roasting on an open fire (sung to the tune of the Christmas Song)
You should definitely add "Songwriter" to your list of skeeelz.
chessrock said:Freshmatty's nippin' at my ass . . .
TonyA's pissed . . . Nitronium thinks I'm a Sire.
And Eric713 just thinks I have no class . . .
La la la la la
StevenLindsey said:some of his posts can be very....how should I say.....warm. Almost...vintage like.
Gotta' have the transformers, you know. I heard that if your recordings aren't warm, it's because they don't have enough iron in them.chessparov said:
Another singer and I took turns singing through it while the other
one listened. It worked the best on our voices out of the SP line when soloed. Keep the B1 for your heavier mixes though as it's more "present" than the T3, and will cut through more.
Also have the B1/VTB-1 combo you have BTW.
You won't be able to replicate the T3 by switching pre's.
Chris
Kevlar said:would i really want to put a 500$ mic on a 125$ pre amp? Not really ha ha
cominginsecond said:Despite all the hype on message boards, mics are far more important than preamps in the grand scheme of things. Getting a decent mic will get you 85 percent of the way there (regardless of what preamp you use). A really, really decent pre will get you the remaining 15 percent.
Hmmm..... well, as always, YMMV, but its been my experience that the pre plays a much greater role than that.chessrock said:That's pretty close. Although I'd say a good mic should get you at least 98% of the way there. A good pre -- or at least one that doesn't suck -- won't take anything away from that 98%. A really good one might get you that extra point, though, to 99 or 100.
Michael Jones said:I can use the same mic, on the same source, but pit my API's and neve-esque pres against some ART's, Aphex's and cheaper dbx's, and tell a big difference.
It is all relative, though, I suppose. Plugging in to a crappy pre might bring that initial 98% back down to 92% or so, which will obviously widen the gap a bit.
