Is your goal to end up with a mono recording? Most (All?) of the 'M' Series equipment is mono only, as is the M68-RM. If that we're my plan I would probably go with an M367 (6 Channel, mono) The M367 has two mono outs, one is mic level and the other switchable between mic and line. It would be easy to use that mixer to record with and also send one of the outs through a processor and back into the M367. Beyond the Mic/line inputs the M series gear has a mix-bus input which you can use as a line in. It's usually on a RCA jack. Feed you 'verb back in there or via a normal input and it will be on the mix-bus outs.
If you're looking for simple stereo, the Shure FP42 is a good place to start. 4 input, plus mix bus, into a stereo pair. They have done some interesting things with the mixer to make them incredibly flexible and the FP42 actually has a separate 'Cue' bus that you can get to via the headphone jack. They were very popular with radio stations.
The M68-RM is a fine mixer and can sound quite good but it takes careful attention to levels to manage the noise floor. The spring isn't bad on the M68-RM but it's also not great
You don't get really any control of it, beyond how much level you get. To record the quartet you describe, I'd want a little more control to help manage the 'sprong' sounds a spring reverb can give off but perhaps that's all part of the sound
I might even consider using the mix-bus out on the M mixer and feeding it into a guitar pedal and then back into the mixer... so many fun ways to use older gear! Eddie Kramer use three M67's to record Woodstock after all...
Robert
