The Behri mic pres get noisy when you push them and the noise isn't linear--it comes on suddenly above a certain amount of gain.
Yes, that's right!  It's kinda... twitchy.  Okay, I said 'full on' but listening back I've still got a bit of hiss.  By turning back the gain knob a nat's whisker from the top, it attenutates the hiss.  Full green on the meter and no yellow.  I've listened in on the headphone channel and with a bit of careful adjustment, I set it so that the hiss just stops.  Then I did a naughty and pulled back the midrange a little (I understand it's best to record dry, with no EQ) but I did, and it helped a little.
Now I've done something even naughtier... popped on a compressor VST before the recorder to knock down some of the heavier spikes (I can do this with my voice when I'm in the right mood - but what the hell.)  If nothing else, I've learned a bit more about compression, being able to see the result.
If I have the gain any less, I get noise, across all sorts of bands, when I normalise the waveform after recording.  With the gain at this (crucial) level, just the faintest, itty bitty hiss in a high register is detectable but is more noticable at higher volume output.
So the gain is up there... and I have the channel slider on the mixer lower.  Just over half, I think.  I haven't touched the main mix sliders 'cos they don't output anything to the E=MU.  They go straight to my listening amp.  Alt 3/4 goes to the E=MU and 3/ is up to the zero notch on the mixer, with the input channel panned hard left (for mono).  I just left it up there and adjusted down the input channel slider instead.
			If his mixer is the same, it might be worth pushing the channel and master faders all the way up and turning down the mic pre to compensate.  This MIGHT reduce the noise a bit.  It's only a 30 second experiment to see if it helps--worth a try.
That's just how things were, when I discovered the noise.  I couldn't get a big enough signal going in.  When I turn the gain knob down a little, the level doesn't go down a little but seems to jump right down.  And when I did normalise after recording at a lower level, I got some noise.
I hope this makes sense.
Yeah, I'm beginning to think this mixer's crap.
