H
Hi_Flyer
OK, so how are you supposed to line these up? Or maybe more specifically how do you *know* that you have lined them up correctly?
For example, a project that I'm working on right now, I wanted to blend a sample with the original tracks, not completely replace the hits. It looked like the polarity of the samples was completely opposite the polarity of the original snare hits. So I flipped the polarity of the samples. Is this the correct thing to do?
What about if the wavelength of the samples is a little bit different than the original snare hits? Should I be looking at primarily the initial transient? Or the whole drum hit (ie initial transient, plus the decay)?
I've been messing around with this stuff long enough that I am starting to be able to hear when the hits are a good bit off, but now I'm worried that the reason my snare hits aren't cutting through the mix is that I don't have them lined up correctly and I have sort of a phase cancellation thing going on. Is it even possible to have phase cancellation between a sample and an original drum hit? I know that technically you wouldn't call it that, but could it be sort of a similar effect?
