E
		ecc83
I very rarely intrude into the 'mixing' section of HR because I have almost never done any. I am however rather confused about some of the content of this thread and disagree totally with one answer.
If there is a track that has gone over 0dBFS then AFAIK you are *****d and you need to either record it again at a lower levels (like neg 20 as we ALL know!) or you might have a 'clip fixer' such as in Sound Forge.
If on the other hand a hot track is causing clipping when mixed with others, turn it down! If that means the mix now does not 'work' (and I am now straying into subjective territory I know FA about!) then the whole mix must drop a few dB AFAICS?
"Analogue circuits in 'budget' interfaces are rubbish and really good ones are hard and expensive to make"
Sorry, total BS IMHO. The 30+yr old NE5532 produces far lower distortion than most capacitor mic pres and less than any active monitor. The later LM4562 op amp is so distortion free that it is difficult to measure even on the best analysers. The NE is cheap as chips and the 4562 not that much more. The 5532 was and is used in a great deal of very 'high end' studio gear.
Mike B I see you have made much the same point as myself but more succinctly!
