jpmorris
Tape Wolf
Long shot, but has anyone here used the MK1 TimeLine Lynx to lock two tape transports together? I've acquired a pair of them without manual - which appears to be extremely difficult to obtain. The deck is a Tascam TSR-8, and I've just this morning constructed (at great effort and ridiculous cost) a cable which should allow it to control one of the Tascams from the cable schematics which are available. Unlike the mess with the MMC100, this time, the EXT light is now flashing on the Tascam.
Now. One of the things I've noticed but not been able to pin down is that the
Lynxes seem to be different. I have a U16 and a U25. This appears to be related to the ROM version (*). One of the things which has been nagging me is that TimeLine might have made different EPROMS for different tasks, in which case they might not be suitable for transport control.
The main question is this. The Lynx has the following I/O:
TC IN, RESHAPE, GENOUT, PILOT IN, PILOT OUT
TC IN is obviously Timecode IN, and when hooked up to the Rees TS1 it decodes the SMPTE and displays the timecode position.
RESHAPE I'm guessing will output a regenerated version of the input timecode for copying/enhancement purposes.
GENOUT outputs a generated timecode, which makes the TS-1's SYNC light come on, although I haven't yet hooked it up to a sequencer to double-check. If the TS1 is happy to lock to it, I'm assuming it's what it says on the front.
Now, the PILOT I/O are the ones I'm curious about. If this Lynx was made to control the transport as a slave, would you feed the timecode from the master machine in here (with the slave machine that it will be controlling on TC IN)?
Or is this something to do with Nagra's PilotTone thing? (These machines were used in a broadcast studio I believe).
If not, would I have to have the other Lynx listening to the master and controlling this Lynx as its slave via RS422? (I don't want to have to make another one of those goddamn cables if I can avoid it)
Anyway I'm going to play around with it but if anyone has actually done this, help would be greatly appreciated.
(*)Yes, it has a ROM but I can't seem to find the microprocessor. I was expecting a Z80,6505,6800 or maybe 8080/8085. Some of the ICs are (C)Intel 1975, which makes the design older than me.
