philbagg
Just Killing Time
I have two KRK Rokit 5's, both bought from Thomann (one single purchase). I was doing some mixing, and I noticed the balance was a little off. I've checked the input gain on the monitors (both 0dB), and the HF Response (both 0). Then I set up one mono track in Pro Tools, and pulled the left channel of a song onto it (Pearl Jam - Even Flow), and started panning hard left and right. They sound different. There's a different response in the bass end (probably due to the left speaker being in a corner - I know, I'm a bad person
) But there's also a different response in the upper mids, and probably some other stuff I can't make out yet.
I thought it could have been the MBox 2, but I've tested the left speaker on its own by panning left in Pro Tools with the speaker cable plugged into the left output, and panned right with the (left) speaker plugged into the right output, and it sounds the same, so that kind of eliminates the MBox 2 (sorry if that sounded confusing)
Any ideas?
) But there's also a different response in the upper mids, and probably some other stuff I can't make out yet.I thought it could have been the MBox 2, but I've tested the left speaker on its own by panning left in Pro Tools with the speaker cable plugged into the left output, and panned right with the (left) speaker plugged into the right output, and it sounds the same, so that kind of eliminates the MBox 2 (sorry if that sounded confusing)
Any ideas?
and I'm not sure how well my room would be able for treatment. The back wall of the room is 3 wardrobes (6 doors), so I can't really put anything across those.
Just needed to get that off my chest
Stick em right up against each other, you're going for relative difference, and that will remove all the room placement issues and not need repositioning.
