MadAudio said:
And who are you?
RandyW said:
You ever notice the GC has all their high end acoustics hang on the wall? They usually have the cheaper ones sitting on stands. So are actually hangs with little leather straps connected to the tuning keys.
Of course they have humidifers and and dehumidifers as well.
Perhaps...but there is no way I am hanging my guitars by their tuning keys.
The dehumidifier is big on my list though.
Thanks RandyW
crazydoc said:
Thanks for lending your crazy, doc.....
Light said:
Your guitar will always be safest in the case. First of all, the case protects your guitar from physical blows which can damage it. Second of all (and perhaps more importantly), the case is a much smaller volume of air, so it is much easier to maintain a consistent environment.
This is one where I can't really tell you what to do, as I keep all of my guitars on the walls (no kids or dogs, plus I don't have enough cases for all of my guitars; it's kind of like the cobblers children being barefoot), but my strong advice is to always keep your guitars in their cases.
Light
"Cowards can never be moral."
M.K. Gandhi
My kids are all grown...I have grandkids, but the same as when my own kids were wee ones...they are not a concern.
They all know the rules of the studio and respect them. I have a 3 yr old grandson, still in the learning process, but he's already learned the NO drinks rule. I am still working on the ask-before-touch one though.
Although is forte' is drums and has a set of his own, he loves to try out the percussion instruments and my keys and is fascinated by my bass when I have it out..(I've given all the grandkids have their own instruments too, so as not to be as tempted by granny's!!!)
...did I just call myself granny?
I've had way more problems with adults than kids.
My, I'm chatty today Light!!
Geesh...all this conflicting advice...I dunno...I think the open display is winning out on this demon turmoil. But if ever I own a real LP...it won't be living on the wall.
You didn't mention the hanging tension on the headstock/neck/body...so I am assuming you agree it is a safe practice too...?
Thanks Light!
knightfly said:
I keep some in cases, some out; but I consider humidity/temperature control more important - any wooden instrument - piano, violin, guitar, etc, thrives best at somewhere between 42-45% humidity and 65-72 degrees or so - it is CHANGES in their environment that are bad more than anything. This, because every time the temperature or humidity changes, the wood parts try to re-balance their moisture content and they MOVE at any joints, not to mention larger surfaces wanting to bow one direction or the other.
A few years ago I bought 4 of these
http://www.natlallergy.com/prod/1526/acu-rite-humidity-monitor-thermometer.html
and I keep one in each area where musical instruments live - if the humidity rises (or temperature shifts by more than about 5 degrees) I do whatever it takes to keep it stable.
Steve
Hey Steve...thanks for the link. Those are very very affordable!
I have an electric violin in a hardcase, but my Cello is in a very thinly padded gigbag(no, I don't play, only make some god-awful racket on them). I should wall display them also!!
Proper care attention has not been given the violin and cello and easy access should help on that...so there is another thought to ponder.
jimistone said:
Guitars in music stores never get put in a case. They just hang there...sometimes for years.
I wouldn't worry about it.
Thanks for the input Jimi
RezN8 said:
hi True- I think you should be fine displaying your axes on the walls. I do agree the finish will fade over time. If hanging from the neck concerns you, then place some support at the bottom to relieve the tension. Maybe you could use the bottom part of a guitar stand for that.
Ultimately, I would choose the area carefully though. Make sure the area on and/or near the wall is a relatively stable environment. In other words, the temp, humidity, air currents do not fluctuate drastically.
(Sorry 'bout all the big words there...)
Anyway, about 20 years ago I came up with this idea for a guitar case with a plexiglass face that you could hand on the wall. It had a built in humidifier and even display lights. I even thought of using UV tinted glass - or use lenses that darken with sunlight - as an expensive option for the most prized guitars.
I showed my dad the plans and he shot them down. I threw the plans in a draw and forgot about them. Now I see they have ads for the exact same product in the back of guitar player mags. Oh well. My point is a display case might offer better protection than simply hanging a guit on the wall.
hope the info helps.
All the best, Rez
Hi Rez!!
The support on the bottom of the guitar is something to think about...Zap brought that option up too...and I think your display case idea for those special axes, is great... be really cool...with the display lights. Makes one think about having a larger recording area.
You know...you could still go with your idea. There are always different versions of ideas and products. Just find out what the other guy has missed or lacks and go for it !!!
Thanks Rez and good luck!!
