W
whitebalance
Hi folks,
A pretty much complete noob here in need of advice.
I recenty got a pair of KRK Rokit 8s. Right now they're hooked up directly to my iMac using a Y cable (RSA to 2xTRS) and I've been hearing a slight but annoying hiss. I did some search, learned about ground loops and DI-boxes and figured I could connect it all using my NI Audio Kontrol 1 to a DI-box to the KRKs. So I went out and bought a Behringer Ultra-DI DI20 figuring it'd be enough to put between my AK1 and the monitors. I then proceeded to connect the AK1's outputs to the DI's inputs using TRS cables and the DI's outputs to the monitors inputs using XLR cables. Seemed like a solid plan, but when I hooked it all up I had no sound. Now, the DI20 is a really cheap box and is supposed to operate on either phantom power or a 9v battery. Suspecting my knowledge of how phantom power actually works is to blame, I pulled a battery from my bass, put it into the DI20 and voila, I had sound.
Two questions: are KRK monitors not supplying power over XLR or am I doing it wrong?
If I have to stick with the battery, anyone has any experience as to how long can I reasonably expect it to last?
Any extra tips/advice much appreciated
Thanks!
Thanks!
