coloradojay
My original post was at:
https://homerecording.com/bbs/showthread.php?t=207663&highlight=kiwi
Basically it says that I lost a channel in my DMP-3 and speculated that it might be the mic cable's fault.
So after running the cable tester again a couple more times, and verifying that indeed my DMP-3 had a bad channel, and reading a couple of "it couldn't be the cable" replies, I figured,
"hey, I need that cable in my rig to track drums, it probably wasn't the cable's fault, I should just get recording again and use it"
BAD MOVE!
I've now toasted channel 2 in my recently aquired Tascam 1884, and I'm pissed (and feel like a dumb-ass for not just tossing that cable in the trash).
After testing the cable again on my analog board, I found that I couldn't get signal with my condenser initially (yes phantom power was on), only with a dynamic. I noticed that the screw in the middle part of the mic side XLR connector had was a little loose, I jiggled the cable around a bit and !KA-POP! it started working again. I think that somehow phantom power may have shorted into the input and has now fried not 1, but 2 of my preamps, on two different pieces of gear!!! F*CK!!!!!!!!!
So now, I'm not sure what to do, should I send the cable to B.L.U.E and try to get them to hook me up somehow for all the damage it's caused? At least a new cable maybe? I've had the cable for over a year so I don't think there is any warantee at this point, and they really aren't legally liable, but I figure it might be worth a try if they want to keep me as a customer in the future. After I tightened that screw, the cable seems to work fine again, but I'm seriously considering whether I'll ever even use another piece of B.L.U.E. gear again. Maybe it should be called B.L.O.W. instead since it seems to blow gear up.
I've seen a lot of crazy stuff happen with electronics, but I didn't pay $40 to get a "higher quality" mic cable, to have it smoke my gear!!!
All that said, I'm only 90% sure it's the cable at this point, there is the off chance that either it's the 012 mic itself which intermittently smokes pres (which seems unlikely, since I'm still using it with another cable and it seems to work fine without blowing anything else), or maybe by some strange universal co-incidence I've randomly blown channel 2 on 2 different pieces of gear in the span of like 2 weeks.
What say you?
/endRant
BAD MOVE!
What say you?
/endRant
