Re: Need More Input
coloradojay said:
Cool Tim,
Could you give more details on the Chicken wire and foam setup? How long is the tunnel? Is it the same diameter as the kick, or bigger? Or maybe just post a link to your old thread if you already eplained the construction.
BTW- I love Joe Jackson. Isn't he touring again? Does that mean new album, or just old stuff?
Well, the way that they made their tunnel, was they made a chickenwire "tunnel" that was 24" in diameter. and 36" long.
The guy was using a 22" Kick.
Then, the lined the inside of it with 2" thick foam, then they stuck this over the end of the kick drum, so that the end of the drum was completely inside of the foam ...probably 2" or 3" inside...
Then they covered the whole thing with those old type of U-hail quilted sound/packing blankets.
(You can get them online for $20 each.)
I was just watching Linkin Park on TV today (they had them in th studio....I don't really care for them, but there it was ...the kick tunnel in front of the kick drum....and it was 3 or 4 feet long....My guess is the longer that you make the tunnel, the low it will go in pitch (since in some ways, it would be like a resonantor on a pipe organ....although, it wouldn't actually "resonate" but simply contain the sound. It also lowers the amount of kick in your overheads.
You are better off using 2 mic;s if you do this...I'd just put a 57 or it's equivalent right on the mallet spot, and then put something else in the end of the tunnel...perhaps even a decent LD condenser.
Tim
