Hi,
I'm using a Yamaha E303 keyboard and i'm just wondering how to plug its outs to interface inputs. There is only one output jack that says "Output/Phones". This suggests stereo and it says this in the specifications (http://www.yamaha.com/yamahavgn/CDA...3&CTID=205000&ATRID=20&DETYP=ATTRIBUTE&LGFL=Y). The specifications seem to suggest that there is also one L and R output but there is definitely only the phones/main output mentioned above (however if someone could check the specs and confirm in case i've misunderstood). So if there is just the one output does this mean I use a stereo jack cable and then a mono adapter to feed the signal into two inputs on my interface? Will the signal be balanced?
Cheers,
Cheers,
