sweetbeats
Reel deep thoughts...
That said ATR informed me that I could used ATR Studio Master on my TEAC to good effect.
Best of luck getting it properly biased...
Aren't you the lucky one? An occasional bad batch of tape is just reality and always has been in the 30 years I've been recording, in commercial and home environments. But then 100% in any field of manufacturing is unattainable, so we’re not just talking about tape. If any tape manufacturer pulled this off they would be the first.![]()
It might not be that hard if you keep the same reference level the deck is designed for.
Cheers,
Otto
I was always under the impression that the bias level needed was related to the formulation and thickness of the oxide, not the operating level to which you set the deck; that a certain formulation and oxide thickness will require a certain "strength" of bias signal, and certain deck's bias amps weren't designed to muster the proper level of bias tone needed to properly excite the oxide. Is that wrong?
But the problems of tape shedding, gook, goo and mush didn't become an issue until manufacturers began to using the tape formulations that have stayed with us to the present day. This isn't a bad thing but it brought new problems such as shedding and stickiness into the equation.
Be good to hear some of what you've done on your 38 / ATR combo Dodge. Why not put up a link to some of it?![]()
Isn't ATR thicker and a bit rougher on the heads though? I've got a roll of RMG 911 coming for my recently acquired TSR-8, so I'll let post up what happens with it. I've run LPR35 and 911 through my RT-909 with no shed, except from the slightly warped reel I was using.
...I would go as far to say that if RMG was the only manufacturer of analog tape I would junk all my analog gear and go full tilt boogie to digital. Just my opinion.
dodgeaspen seems to have the world's worst luck, because he's had a thoroughly rotten experience with a product that thousands of other customers have been completely satisfied with.
My offer still stands: I'll ship you a brand new reel of 1/2" RMGI SM911 if you promise to take macro photos of your 38's transport after recording fifteen minutes on that reel. Gosh, I'll sweeten the pot even further and include an ATR 1/4" splicing block, to compensate you for having sullied your deck with that lowly, lowly RMGI tape![]()
Thanks guys for the last few posts. I needed a good laugh and I got it. I'll except your challenge!! I guess I might be overreacting a Tadd, but after 2 reels with different batch numbers I tend to think it was the tape manufacture. I was even asked to send RMG picks of my transport system for a deck that just came out of service with flying colors. I even sent picks of the q tips after 500 feet or so of use. Also, I can hear a huge difference in highs between the RMG and ATR. As I said in a previous post I have a strange noise when I convert analog to digital. That's why I haven't posted any of my recordings. PM me if your serious.
I actually need to tweak the bias up a bit on my TSR-8, It seems a little to toppy. Even though 911 is bias compatable with the factory specified setting of 35 mv. The factory setting was for 456. I think I will increase it by 2 mv and see how it sounds. I still have plans to make that tape for you, I just cant seem to catch up with all my projects.VP, I have noticed the bias is a little touchy on the highs, but the mids and lows have not suffered as a result. It in all honesty it should be recaled to the ATR but I don't have a cal tape or the $$$ right now.
VP
No problem! I didn't think you'd forget. BTW do you have the walls done in the studio yet? I'd like to see some more pics when your done.
