Isolation Booth
  • Thread starter Thread starter amit_work
A
amit_work
I have a small project studio that I am trying to make a little more condusive to recording vocals. I'm not bothering with separate studio rooms because I simply don't have the funds or the space for it. But, I do however want to build a small (4X4) vocal booth in the corner of my room. The one room that have is 12'X12' so I don't have a lot of room to work with.
Anyway, does anyone have a good design for building a stand-alone booth? I don't want to damage the walls or anything (since I'm renting this space), so I'd rather just build it independent of the existing walls, i.e., the booth should have it's own four walls, ceiling, and possibly a floor if necessary. Any help would be a great. Thanks!!!
-- Amit
Budget
I should probably mention that, I was hoping to do the whole thing in $500. Am I crazy?
Re: Budget
Qty Price Description
8 $160 3/4" 4x8' plywood used as double layered walls
4 $ 20 2x4"x8' douglass fir studs (corners,
this is what you mount your plywood
walls to)
1 $120 Pre-hung door of your choosing
1 $200 Auralex foam kit for soundproofing on the
walls of the booth.
Plop the whole thing on a piece of carpet
Tack a piece of carpet on the ceiling
Aside from a few mic cables and jacks, you have yourself a cheap vocal booth. It works well too.
The double plywood makes for a sound barrier due to density. They should be glued AND screwed together. The studs mount in the corners of the four double-layer paneling, thus giving it support. You might even want to run a few pieces along the perimeter across the top for additional support, at the cost of two more 2x4's.
Thanks
Thanks Fred!!
This sounds like a fairly easy and cost-effective solution. I think I'll look into it.
Re: Thanks
amit_work said:
Thanks Fred!!
Caulk everything! Then, caulk it again!
Its not the perfect booth, but it works acceptably. Please keep that in mind.
The one I'm making is the same as I mentioned above, except its going to be hinged, so it can be folded to 1' thick against the wall.
This way its out of the way when unused.
Markertek makes a prefab vocal booth. you might want to check it out at markertek.com- look in the acoustic foam section of their site
