B
Bigus Dickus
I was unsatisfied with the stereo field I was getting on my X/Y recordings of my piano. Wide spaced mics sounded "artificial" and X/Y sounded too centered, even with hard L/R panning.
This afternoon I ripped several clips from classical piano works I have to use as a reference, and began a serious attempt at establishing a baseline for compression, reverb, and EQ to get as close as possible to the "great" sounds on my favorite professional recordings. I made a lot of progress.
During the EQ process I stumbled on something I hadn't thought of before; cutting most low frequency information from the right channel and most high frequency information from the left channel.
I recorded a passage that I had two nice professional records of. Using parametric EQ and my ears, I was able to bring my sound much closer to the professional recordings. But still, my stereo placement was much more "centered" than the pro recordings. That's when it struck me to simply remove bass from right channel and highs from left channel. Amazingly, the stereo field opened waaaay up. To figure out the proper EQ (and it was difficult), I summed the tracks to mono and used a spectrum analysis, comparing it to the spectrum analysis for the summed-to-mono pro recording. After a couple of hours, I was able to keep the summed spectrum looking like the pro recording's spectrum, and simultaneously having a bass/treble accentuated L/R separate EQ settings.
The final left EQ curve starts with a +3db boost on the bass shelf, keeps steady until about 100 Hz, and starts curving downward until at 20000 Hz it's down about -12db. The final right EQ curve starts with about a -12db cut on the bass shelf, curves up until it's a +3db boost around 800 Hz, and then tapers back down to around -4db at 20000 Hz (my original tracks had much more high frequency content than any of the professional recordings I have).
I know the usual saying is "if it sounds good, it is good" but I was just curious if this was a proven technique, or if it might cause unforseen problems that I'm not familiar with.
