R
rhythm
Just got a new DMP3, and after unpacking it and doing a quick initial checkout I noticed a couple of things that I'm wondering about:
- Both of the channel gain knobs have small areas in their travel where the movement seems to "bind up" and it's noticeably harder to turn than in the rest of the travel. I would have expected the travel to be pretty uniformly smooth throught the entire range.
- When the unit is powered up, I notice that on channel 1 when moving the gain knob counterclockwise from its max position, when I move through the area where it's harder to turn the knob, the needle on the VU meter shoots up to max for a morment then back down. This doesn't happen at all on channel 2 (needle never moves). I'm wondering if this indicates any issue, since it's not happening on both channels...only channel 1.
Are these things normal? If I return this one and get another would I just find the same things, or should I expect to not see this on a new unit?
Thanks.
Thanks.
