I thought the drums held their ground even under the wankery!
The lead guitar sounds really good in the upper registers....then, like you mentioned, the low end loses sharp focus, and blends like wet paint with the rythm gits. Some tweaking. Yeah, bass up. The meandering bass line in a middle section line kinda dumps the groove, I think.
I also thought that , maybe, one of the rythm guitars could be edited out...there are two??
Tune reminds me of 70's/80's Jeff Beck and/or Al Holdsworth stuff.
You got some nice guit chops. Ever listen to Beck or Holdsworth? A little homework there might help you sharpen your melodic instincts.....like, more of it...melody.
The fast hammer-on/flick-off sequences were nice; but the earlier ones started on the 'ones' of the measures...and required a dead-space 'set-up' for execution. Makes 'em sound stiff. Try sliding one of those clips back in time a beat or two, to provide some pickup notes...like some of the later ones. I notice that your soloing generally follows the changes, instead of leading them......so you might have some hugely interesting, momentum-filled tonal anticipations by sliding some stuff back in time.
Unless, of course, you're a purist!
That was a good work! There are spectacular sonic moments filled with well-blended energy. Just about 30 years late, genre-wise. But everything old is new.....right?
It's kinda jazzy....the bass could use some more articulation in the lines...and a more present sound, maybe. My only other crit is that some of the drum rolls, I believe, are identifiable loops or cut/paste programmed dots.
