bueno,
aquí tenemos una canción en una "genre" la cual no oimos mucho en la idioma Castellana. Se escucha bien.
Very nice groove... and the playing is tight.
Some of the vocals (the soaring ones) "mi corazon..." are a bit flat... maybe there's too much reverb on that chorus "es esto todo"... the bass & kick drum seem to fight just a wee bit throughout... a slightly wider "slot" cut from the bass at around 90-100 would help the kick & you could then turn the kick drum track down some. A slight, narrow cut on the snare at 8kHz (only about 1db) would help it sound less "cheap".
Now, I know spanish (as a 2nd language, anyway
)... and some of the words are still buried... a suggestion is to carefully go thru the mix, and wherever a word is buried, boost it in the mix. A volume envelope works well in a daw, or automation... If you have to do it by hand, it could really tie you up
Guitars & bass seem to have some overlap, too. "Jigsaw" them a bit e.g. find the freq's that sound the best on both guits & bass, and "trade" (cut, for instance 1500 on guits, and 600-1200 on bass)... but not deep cuts...
Those rim hits are very nice...
¡Viva la canción!
