A
alscu
heyy...i'm thinking about getting a beringher ub802 mixer and a xm1800s microphone for computer
recording(mostly voices and micropohned, acoustic guitars, and maybe some
keys)...i was wondering if that setup would be suitable with my soundcard..and also if you think it's a good idea to buy that...the mixer is 100$ and the mic is 20$ ....my sound card is a creative soundblaster 5.1 with the following specs:
Reference signal is set at 1kHz Frequency Response @ –1dB
10 Hz to 47KHz Record & Playback Sampling Rates
Recording (8 supported sampling rates); 8.0KHz, 11.025KHz,
16.0KHz, 22.05KHz, 24.0KHz, 32.0KHz, 44.1KHz,
48.0KHz
Playback: Any arbitrary sampling rate <= 48KHz Line In Full
Scale Input 2.0 Vrms Line Out Full Scale Output 2.0 Vrms
Microphone Full Scale Input 0.2 Vrms (without 20dB boost)
CD Audio Full Scale Input 2.0 Vrms
Microphone Input Impedance 5.0Kohms Line In Impedance
10k ohms CD Audio Input Impedance 10k ohms
LINE_IN / LINE_OUT @ 2Vrms, 1kHz (Measured with band
limited filter from 22Hz to 22kHz)
Signal To Noise Ratio (SNR) 94 dB. (A-Wtg)
Total Harmonic Distortion 0.006% +Noise (THD+N)
LINE_IN / LINE_OUT Record & Playback @2Vrms, 1kHz
(Measured with band limited filter from 22Hz to 22kHz)
Signal To Noise Ratio (SNR) 82 dB (A Wtg)
Total Harmonic Distortion 0.02 %+ Noise (THD+N)
1 ( 1 ) x audio line-In
mini-phone stereo plug 3.5 mm female - 1 ª 1 ( 1 ) x
microphone input /
mini-phone mono plug 3.5 mm female - 1 ª 1 ( 1 ) x gameport
/ MIDI generic
/ 15 PIN D-Sub (DB-15) female - 1 ª 1 ( 1 ) x audio SPDIF
output / Phono (RCA) plug female - 1 ª 1 ( 1 ) x audio line-In
/ male - 1 ª 1 ( 1 ) x audio line-In / 4 PIN MPC male - 1 ª 2 ( 2
) x audio line-out /
mini-phone stereo plug 3.5 mm female - 2
THANKSSS
48.0KHz
microphone input /
/ MIDI generic
THANKSSS
