systmovadown
is there a way to undo effects?
(because i cant undo the effect and my shit is basically fucked)
Yeah..."Edit" tab. "Undo" - hope you didn't close the program.systmovadown said:is there a way to undo effects?
D-Cipher said:you can always undo effects...but not after u close the session and re-open it .
thats why i would suggest applying ur effects in the multitrack via the FX button ....that way no changes are saved to the wave itself...and u save all the original recordings....and can go back and re-mix whenever u want
thats the only way to go ...
dobro said:That 'do it all in Multitrack using the Effects Tab' is marvelously good advice for everything but reverb. I can run loads of EQ and compression on any number of tracks in multitrack, but as soon as all that reverb math starts to kick in, the computer starts to really labor. Of course, you can use Quickverb instead of Full Reverb in multitrack, but it *still* burdens the computer, plus it doesn't sound as good or do as much as Full Reverb.
So, here's a workaround, which takes time but gets the job done: when you've got all your tracks ready to start mixing, double-space the tracks you want to add reverb to - leave an empty track between all your tracks. That way you can make a clone of the original track and bung it into the empty space above it. Then you take the clone into Edit View and apply reverb to your heart's content. Save what you do. Have a good sleep. Listen again the next day, and if you still like it - great. If you don't like the way the reverb's done, then delete the reverb clone and go through the cloning/reverbing process again. It takes time, but it gets the job done.
Yeah, that's what I do...Same thing that dobro's doing, but it's quicker and automatic. HOWEVER, if hard drive space isn't a problem, be sure to check the "SAVE LOCKED TRACKS" box in the options so your sessions load super quick instead of with that annoying "locking track x" thing.aaroncomp said:In Audition, when you are finished with the individual track, you can "lock" the track - essentially, this creates a temporary file with the effects applied - thus, the original file is unaltered, and no extra CPU/RAM power is needed. You do have to unlock it, etc. to readjust, however.
